Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
exporting from a CAD program to a DWF file
5 REPLIES 5
589 Views, 5 Replies
When exporting to a ASCII or Binary DWF, file the file appears as all white on the Autodesk Design Review viewing screen rather than the entity colors from the .dwg file.  How do I correct this?
5 REPLIES 5
pendean
Please define "exporting" and from which CAD program... .
in reply to: pendean
Exporting means saving a .dwg file in some other format, such as .dwf or .pdf. I am using Bricscad version 12
pendean
So you are asking about creating a DWF from BRICSCAD, made by someone other than Autodesk? How do you know it creates colored binary DWF files? Are you sure there is no setting in the program to turn colors on and off? YOu can do so in AutoCAD for example using plot style tables... .
How would asking over here (the viewer) fix a problem that may already reside in the DWF? Just curious.
Can you share the DWF?
thanks. changing the plot style settings cleared up the problem
pendean
Glad it was a simple fix.
