Design Review
nddesign
Message 1 of 7 (1,137 Views)
Windows 8.1 and Design Review
1137 Views, 6 Replies
03-31-2014 03:14 PM
Will Autodesk Design Review 2013 (the latest version I believe) work correctly under WINDOWS 8.1?  and if so where are clear instructions from autodesk for installation if it requires any dependencies / trickery to get it to work.  (The system requirements for design review says windows 7 or XP). Thanks.
pendean
Message 2 of 7 (1,129 Views)
Re: Windows 8.1 and Design Review
03-31-2014 04:33 PM in reply to: nddesign
ADR2013 is not supported in Win8/8.1, just like the system specs say, so there are no instructions.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
nddesign
Message 3 of 7 (1,125 Views)
03-31-2014 05:10 PM in reply to: nddesign
Thanks for reply.  Unsupported, yes I know, but does anyone have it running correctly under windows 8.1?
pendean
Message 4 of 7 (1,104 Views)
04-01-2014 06:37 AM in reply to: nddesign
Microsoft posts a lot of information on how to run old software in newer versions of Windows: start there while you wait here.
peteh
Message 5 of 7 (1,092 Views)
04-02-2014 05:25 AM in reply to: nddesign
I installed DR 2013 on Windows 8.1 and it seems to work fine.  Although, unless you have a touchscreen I'm not sure why you would want to use Windows 8.
Member
Spurred
Message 6 of 7 (1,087 Views)
04-02-2014 07:59 AM in reply to: peteh
I have Windows 8.1. I do not have and do not want a touch screen. I have Windows 8.1 setup to boot into classic start menu and have tweaked 8.1 for the classic desktop. I haven't seen charms or the touch screen interface for Windows 8.1 at all, unless I choose to access it for a specific reason. Windows 8.1 is the latest version of the OS and should offer improved performance. It's based on Windows 7.
I jumped from XP Po to 8.1 and am very comfortable in 8.1. There is no need for a touch screen. My Wacom tablet is much more acurate than my finger for graphics work or most everything else. The newest Wacom tablets even allow you to use swiping, pinching, and other touch screen actions if you want to use a non-touch screen monitor as a touch screen monitor. There's no reason to shy away from Windows 8.1, except to wait for Windows 9.
Active Member
supportinformatique
Message 7 of 7 (1,069 Views)
04-02-2014 01:51 PM in reply to: nddesign
I tested it with a Microsoft Surface Pro running Windows 8.1 Pro, the program works well. But it freeze when I try to close the annotation panel by pressing on the X with my finger or with the pen. With the mouse, the panel close without problem. To solve the problem, I disabled the automatic launch for Annotation, annotation properties in the Options.
You are not logged in.
Ask the Community
