When you have 12345-678.dwg open in AutoCAD, you use the Markup Set Manager
to open 12345-678.dwf. This loads the markup from the DWF against the
geometry in the DWG.
wrote in message news:5805994@discussion.autodesk.com...
My company has just started incorporating Autodesk Design Review into our
drawing processing procedure and I've come accross some issues. Is there any
way to open the markups after you have the original drawing already opened?
For instance, I'll have drawing 12345-678 opened up and I know that there is
an existing .dwf file for this drawing with markups created. When I open the
Design Review manager and open the 12345-678.dwf, it says that the drawing
is already in use and asks me if want to open it in "Read Only". Why won't
it just insert the markups onto the drawing 12345-678 that I already have
opened?
It does me no good if the drawing that contains the corrections is in "Read
Only"! Can anyone help me out?
