I'm trying to run a Mercedes program called Web ETM and Starfinder on my new 64 bit pc. It says that I needed to install Autodesk WHIP. From my research I figured this product is now called Autodesk Design Review, so I installed this program only to find out that it doesn't work. I still cannot open my Mercedes program. Please help! Urgently need program to fix car.
What do I do in order to get program working on my new pc??? Please help! Need to fix car and have no other pc on hand.
same problem with no read of star service dvd with 64bit computer..called benz..said enter www.startekinfo.com and click help
enter information...I am waiting 48 hours for response
old computer works..with autodesk whip..
ed
WHIP was a 32bit program and it is no longer being developed and there is no 64bit version of it.
You need to move your questions to the other company that still uses WHIP for a fix of your issue.
And keep your old computer for now.
thanks for MB solution
I am still waiting for an answer from MB ...startekinfo.com
unforunately I gave old computer to niece
I was hopeful a 64 bit could run 2 32's bit
I'll forward MB's answer when I recieve it
f
mercedes....stated..download "design review 2011... 64bit" from autodesk
and mbusa.com 64bit reader
did it..works
A 32-bit WHIP! should run in a 64-bit environmnet.
ftp://ftp.autodesk.com/pub/whip/english/whip.cab
Hello..after installing autodesk review..I still needed MB 32--64 bit, which I downloaded from mercedes.
not sure..but it works
thanks for help
fred
i've installed the Autodesk Review 2011 for 64bit but everytime i start the Mercedes Benz service disk program (viewer.exe), it still checks for the whip32.exe and won't go further.
please how do i get past this step?
thanks in advance,
Bimbola
I searched on the MBUSA website and I cannot find the link for the 32-64 bit viewer. Do you have this? this inablity to use my StarTek disk is driving me crazy thanks.
the workaround for the StarService Manual CD/DVDs can be found here:
https://www.startekinfo.com/StarTek/outside/50857/images/downloads.html
Step 1 disables the start-up check for Whip!
In Setp 2 and 3 you download DR and request the data for your model
http://labs.blogs.com/whip4.exe">Download whip4.exe (3628.6K)
My computer is a 32-bit computer. I need the 32-bit whip to work on my MB Web ETM programs. Where can I download this 32-bit whip? Auotdesk had removed the link! The 64 bit whip would not work inmy old computer. Please help, thank you.
On a Win 10 x64, I added only the STAR_ServiceManual_x64.reg (from instructions at https://www.startekinfo.com/StarTek/outside/50857/images/downloads.html)
The Viewer.exe on the MB Manual CD started to work.
