I am using attributes in which i place values using vba (or manualy) these blocks and the attribute data are being exported to a database.
This works fine.
When i make a nested block with these blocks i should expect that it is possible to assign different values to the attributes of a nested block.
This is not the case, after saving the block all the attributes are having the same attribute value.
So what it should do, is the natural behaviour of the attribute, is to assign different value's to the attributes of the nested blocks.
How do i get this to work right?
