I generated about 50 A1 dwf files in Revit which all appear to be fine, however it seems that the ones with more information can't be opened with Autodesk Design Review 2008. The screen just turns grey and then hangs after getting about 50-80% through loading depending on the file. This very frustrating as I need to open these files so I can print them and I issued these files to a client for them to print and hope they aren't experiencing the same issues.
They were generated using the Print to DWF 2d option in revit rather than the export to dwf option (due to display issues that exporting causes).
Is there a solution to this issue.
My PC isn't slow and has 2GB of RAM so I can't see why this is happening.
Thanks.
