Hello!
I have a big problem and I try solving it since last week, but I didn't get any positive results.
Here is my big problem:
I installed Design Review 2011 and DWG TrueView 2011 on an account. When I tried to open a .dwg with Design Review on the same account it works perfectly. But when I try to open the same file with Design Review on other account a get some error (DWG file can be open only if latest DWG TrueView version is installed). If I run DWG first and then Design Review, the dwg file is opened without problems (after runing DWG a self-healing is started). If I force a self-healing for DWG (with active setup registries using /fus parameter), when I run DWG an error message saying: "Cannot find configuration file..." appears and I can't open dwg file with Design Review (an error message with "Cannot import file" appears).
Please help!
In Windows Explorer on the problem machine, what is the DWG file extension associated with for an app/launcher?
Compare with the trouble-free PC.
