Design Review
New Member
h.leonard
Message 1 of 8 (642 Views)
Transparency of colours not printing out
642 Views, 7 Replies
06-01-2006 07:52 AM
Fill colours that are set to transparent in the DWF drawing, do not print out as transparent in the hard copy or in a PDF copy. They print as solid colour therefore obscuring the drawing below. Is there a way that the transparent fill colours can print out as they appear on the DWF drawing?
*Scott Sheppard [Autodesk]
Message 2 of 8 (642 Views)
Re: Transparency of colours not printing out
06-01-2006 09:31 AM in reply to: h.leonard
Please send me the DWF. Transparent colors are supposed to print as they
appear on the screen. If you could also send the source file, that helps tie
break between the DWF Viewer and the application that published the DWF.
wrote in message news:5192184@discussion.autodesk.com...
Member
hughl
Message 3 of 8 (642 Views)
07-03-2006 05:02 AM in reply to: h.leonard
Thanks for the reply.
I am not sure if you require the original DWG file, if so, can you let me know.
For now, I attach the DWF of a drawing, then the same drawing with transparent colours added and finally a PDF to show how this drawing prints out.
Hugh
Member
hughl
Message 4 of 8 (642 Views)
07-03-2006 05:05 AM in reply to: h.leonard
DWF file with transparent fill colours
Member
hughl
Message 5 of 8 (642 Views)
07-03-2006 05:07 AM in reply to: h.leonard
PDF of the DWF file to show how it prints out
Message 6 of 8 (642 Views)
07-05-2006 09:55 AM in reply to: h.leonard
I was able to print the DWF with proper transparency on my HP device. I used
Autodesk Design Review 2007. I have attached a scan of my printout. You can
see the red text and other objects behind the transparent areas.
wrote in message news:5225547@discussion.autodesk.com...
know.
out.
Hugh
New Member
s1newman
Message 7 of 8 (503 Views)
08-03-2011 10:43 AM in reply to: *Scott Sheppard [Autodesk]
I am using ADR 2012, and have very similar problem as discussed above. Although I can print out the fill colour as transparent in hard copy, it will present as solid colour when I PDF the drawing.
Please advise.
Employee
wube
Message 8 of 8 (493 Views)
08-04-2011 11:20 PM in reply to: s1newman
Could you please attach a test file to this thread for deep investigation?
Ben Wu
SW Engineer
PSEB-GE-ACRD
You are not logged in.
Ask the Community
