Hi All,
I know there are others that have posted similar questions, but I still haven't found an acceptable solution. We have autodesk design review and we imported symbols that we frequently use on PDFs in the program. The problem is these symbols make the PDF file HUGE once resaved. it will go from 22,715 kb to 194,332 kb. We do add alot of symbols, but they are all completely necessary. Is there anyway I can reduce the size of the symbols somehow? Compressing the PDF after does not do much, and neither does changing the DPI of the PDF conversion.
Any help would be greatly appreciated.
alyon
