Is there a way to reverse the mouse wheel zoom in/out function, similar to the AutoCAD command ZOOMWHEEL or changing the setting in Application Options for Autodesk Inventor? I searched the forum and could not find an answer.
Solved by rkmcswain. Go to Solution.
I would also like to know the answer. It feels like it has been setup wrong.
Yes, thank you.
I couldn't find those options at first. They weren't on the ribon or the File menu. Had to right mouse click the view of an open document.
Or, choose "Options" from the Application Menu.
