Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Rename existing Symbols - Design review
4 REPLIES 4
FlippiedB
2178 Views, 4 Replies
Good Day All
I recently created a Symbol catalog in design review 2013. every thing works perfect except i cant rename the symbols in this catalog.
Any Ideas. PLZZZZRobot Frustrated
4 REPLIES 4
cblocher
in reply to: FlippiedB
From the Symbols button drop-down list, click Manage Catalogs.
Select the one you want to rename, click Rename and type the new name you want.
FWIW, you cannot rename an individual symbol in a symbol catalog once it has been created.
Hope it helps,
C.
Chris Blocher
Content Strategist, CXD
Fusion 360 Product Documentation
FlippiedB
in reply to: cblocher
hi Chris
That helps a bit. can we put it on a wish list for te next design review to rename each symbol.
Thanx
cblocher
Gladly!
Added "Rename Existing Symbols" to the wishlist.
Best,
C.
Chris Blocher
matthew_taylor
Hi guys.
I know this is an old thread, but I've worked out how to do this.
Once you have imported your catalog, export it as a .sym file.
Open that file in Design Review (you'll need to change to 'all files').
Rename the sheets - there is one sheet per symbol. This will be your symbol name in the catalog.
Save the file as a .dwf.
Then use the 'Create Catalog from DWF...' command to import them.
You'll need to add the name of your catalog again.
I did this in Autodesk Design Review 2013.
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
