Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Read Only File
1 REPLY 1
TKArchitects
633 Views, 1 Reply
Read Only File
One computer in our office will only open design review files as Read Only.  It doesn't matter if no one else is in the file, it doesn't seem to matter how the file is opened.  Once the file opens it is read only.  Which means he can do markups but has no way to save them.  I looked under Options but didn't see anything there.  Tried restoring to factory defaults there, no luck.  We have uninstalled and reinstalled Design Review and run the Hotfix and still cannot get it to open a file without making it read only.
Theresa
1 REPLY 1
pendean
in reply to: TKArchitects
If you placed a DWG file on the user's PC in their working folder, does the problem go away?
OR
if you log in as yourself on that PC does the problem go away (assuming you yourself do not have this issue)?
You seem to be describing a network-level read-only tag at the folders this PC is accessing: there is no fix for it inside the app.
