I am able to programatically select 3D objects via the javascript API (see my previous post). I would now like to programatically move the camera such that the selected object is centred in the camera.
I have been able to do this with 2D objects by getting the objects Extents then setting the Section view. But this approach is not applicable with 3D.
Any help appreciated.
Cheers
The reply to the following post seems to suggest that programatically moving the camera to the selected object is possible:
http://forums.autodesk.com/t5/Autodesk-Design-Review/Zoom-the-object-in-3D/td-p/2548696
The extents property has Front and Back properties in addition to Left, Right, Top, Bottom.
But the Camera position has X,Y,Z co-ordinates...
So how do you use the extents to set the camera position?
Another tantalizing post:
For 3D bojects:
2. Define your specify EModelCamera object base on the boundaries (IAdCube).
3. Set you specify 3D view to render objects via EModelSection.Camera property.
How do you "specifyEModelCamera object base on the boundaries" in Javascript?
