I have packaged ATV 2013 for deployment but it is not being detected by ADR 2011/2012 as being installed so ADR will not open DWG files. 2011 works fine but 2013, no go...
Error message is 'DWF Convert Error - Problems encountered during DWF import'. There isn't much on this is the release notes or the AutoDesk forums.
Did your team figure out the issue? I am trying to open a PDF file in ADR and I am getting the DFW import error.
10 years on and the problem still exists, Surely you guys must have figured out a solution by now?
