Design Review
New Member
chucky12
Message 1 of 2 (402 Views)
Problem orientation cube Inventor2010>ADR
402 Views, 1 Replies
11-26-2010 02:55 AM
When i export a .iam to dwf, the orientation of the cube is differtent in the dwf.
The origin form the .iam is good, also the orientation of the cube is o.k. (top is the topview)
When I use the option (right click on the cube) ''reset front'' the cube its also o.k.
Why can ADR not copy the right orientation?
In ADR is the topview of the model > front (cube)'
Can someone help us?
Employee
Message 2 of 2 (346 Views)
Re: Problem orientation cube Inventor2010>ADR
12-13-2010 12:17 AM in reply to: chucky12
Thank you for reporting this issue.
We had logged a defect ID 1028174 against this issue. We're considering to fix it in further releases.
-Spring
Spring Ai
SQA Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
