Ok, Lets restore the files you removed (or replaced) and I'll work with our
engineers some more.
"Gilles Plante" wrote in message
news:40d6d714_3@newsprd01...
> John.
> 1) right at the start, Script Error in toolbar.htm
> 2) again, Script Error in toolbar.htm. By clicking here and there, zilions
> of other errors pop in, the drawing gets displayed and the toolbar still
> displays the gradient color.
> Gilles
> "John Schmier (Autodesk)" wrote in
> message news:40d35c4b$1_3@newsprd01...
> > Ok, I've got a few things for you to try:
> > 1) Try running embedded in IE or some other app to see if the
toolbar.htm
> > also malfunctions.You can do this by dragging a DWF into IE, the DWF
will
> be
> > displayed in IE.
> > 2) Put the orginal toolbar_exe.htm back in and see if things function
> > properly. Are the toolbar icons awkward looking or just the menu icons
in
> > the dropdown menus?
> > news:40d33e92_2@newsprd01...
> > John,
> > some things have changed. The menus do not display anymore the blue
> gradient
> > color, but the icons are awckward looking. When the program starts,
there
> is
> > an Internet Explorer Script Error:
> > Line 463
> > Char 9
> > Permission denied
> > in toolbar_exe.htm
> > The toolbar does not show up. I can't turn it on, because menus don't
work
> > at all. There is alway a Script Error.
> > Gilles
> in
> > message news:40d335d1_3@newsprd01...
> > The developer would like you to try something.
> > 1st Go to the directory you installed Composer to.
> > Rename the files aev_style.css, toolbar_exe.htm, and toolbar.htm in
his
> > eplot subdirectory
> > Then place the attached files into that directory.
> > Let me know if this has any affect.
> in
> > message news:40d318ee$1_1@newsprd01...
> > > Well, I've exhausted about everything I know how to try. I've sent
> the
> > > problem off to the developers who wrote this up, let's see what they
> > > recommend.
> > > news:40d2eb92_1@newsprd01...
> > > > John,
> > > > all the IE properties you mentioned are as you expected. The IE
> > version
> > is
> > > > 6.0.2800.1106IC SP1.
> > > > The other computer which is as mine uses the same video card and
the
> > exact
> > > > same driver and version of the driver.
> > > > DWG viewer and Volo View are also installed on this partition.
> > > > Gilles
> wrote
> > in
> > > > message news:40d20c65$1_1@newsprd01...
> > > > > Well, the 1st thing I can tell you is Composer is using gradient
> > > color's,
> > > > so
> > > > > if you know of a setting where this has been changed, you may
want
> > to
> > > look
> > > > > at that. Otherwise, can you take a look in 2 specific places.
> > > > > Internet Explorer
> > > > > Right mouse click on the IE icon and select Properties (or start
> IE
> > and
> > > > > select Tools --> Internet options)
> > > > > Select Colors from the General tab
> > > > > What is the settings here? By default they should be:
> > > > > Colors: Use Windows colors
> > > > > Links: doesn't matter in this case
> > > > > Now, lets look at the Accessibility on that same tab. They
should
> > all
> > > be
> > > > > unchecked, if not try unchecking them all.
> > > > > news:40d1f370$1_1@newsprd01...
> > > > > > John,
> > > > > > I know a little bit more now.
> > > > > > The problem I have is particular to my PC. I tried DWF
Composer
> on
> > > three
> > > > > > other machines, of wich one is exactly as mine, and all ran
> > Composer
> > > > fine.
> > > > > I
> > > > > > applied SP3, but it did not change anything.
> > > > > > Something on this partition is disturbing DWF Composer, but I
> just
> > > don't
> > > > > > know what to look for. I am willing to help you solve this
> issue,
> > so
> > > if
> > > > > > someone else experiences this, Autodesk can provide a
solution.
> > But
> > I
> > > > need
> > > > > > clues as to what to search for.
> > > > > > Thanks
> > > > > > Gilles
> > wrote
> > > > in
> > > > > > message news:40d1b721$1_2@newsprd01...
> > > > > > > I should have asked for this earlier. Can you provide a
> screen
> > shot
> > > > of
> > > > > > the
> > > > > > > problem?
> > > > > > > news:40d1b6a0_2@newsprd01...
> > > > > > > > John,
> > > > > > > > here we are:
> > > > > > > > Windows 2000 SP2
> > > > > > > > Scheme: Windows Standard, default colors and fonts
> > > > > > > > Adapter: S3 Trio32/64
> > > > > > > > Driver version: 5.0.2184.1
> > > > > > > > Going to 32bit color, but 800 x 600, does not help either.
> > > > > > > > Thinking about this, would Autodesk have used regular
menus,
> > we
> > > > would
> > > > > > not
> > > > > > > > have run into this problem. Flashy guizmos à la Microsoft
> does
> > not
> > > > add
> > > > > > any
> > > > > > > > functionnality, only troubles.
> > > > > > > > Gilles
> > > > > > > > "John Schmier (Autodesk)" > com>
> > > > wrote
> > > > > > in
> > > > > > > > message news:40d1ad0f_2@newsprd01...
> > > > > > > > > We have looked at the color depth and DPI settings.
What
> > other
> > > > > > > > > customizations have you done for display? Have you
> altered
> > the
> > > > > > > Appearance
> > > > > > > > > (such as Color or Font's) for the menu's and toolbars
for
> > your
> > > > > system?
> > > > > > > Is
> > > > > > > > > there a specific "scheme" you are using or any 3rd Party
> > > > > applications
> > > > > > to
> > > > > > > > > alter the display on your system?
> > > > > > > > > What graphics card and driver version are you running?
message
> > > > > > > > > news:40d1990e$1_3@newsprd01...
> > > > > > > > > > Doug,
> > > > > > > > > > what details are you looking for ? I will provide them
> to
> > > John.
> > > > > > > > > > Gilles
> > > > > > > > > > "Doug Look, Autodesk" wrote
in
> > > message
> news:23928461.1087437845329.JavaMail.jive@jiveforum1.autodesk.com...
> > > > > > > > > > > Gilles,
> > > > > > > > > > > This sounds like a bug that we've run into before.
If
> > you
> > > > could
> > > > > > > > provide
> > > > > > > > > > more details to John, hopefully we'll be able to
figure
> > this
> > > one
> > > > > > out.
> > > > > > > > > > > Doug
