Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Mark Ups- Weld Symbols
7 REPLIES 7
Message 1 of 8
feldwill
896 Views, 7 Replies
Is there an add-on to design review or some other Autodesk software that has weld symbols for mark up (or may be some other technique).
Thank You
Regards
William
7 REPLIES 7
Message 2 of 8
dickyshu
in reply to: feldwill
Hi William,
Thank you for posting your problem here.
As far as I know, there is no such add-on to design view to import weld symbols for markup.
Below is a workaround for you:
Try to find a dwf with weld symbols as object at first, then
<1> Run ADR;
<2> "Markup & Measure" tab->"Symbols" button->"Create Catalog from DWF..." command;
<3> Select the dwf file you found;
<4> In "Create Catalog from DWF" dialog, choose "Import each object on sheets as a symbol" option;
After the weld symbols have been imported as custom symbols, you can add them to your file via:
"Markup & Measure" tab->"Symbols" button-> the catalog you imported in step 4.
Note:
This is only for 2D.
Hope this helps.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
Message 3 of 8
feldwill
Tried it and it works, not as good as having symbols build it being fully customizable.  Is there a chance you can export these imported symbols for other ADR users.
W
Message 4 of 8
dickyshu
I am afraid the answer is no so far.
Your suggestion is a good idea and has been recorded by us, please pay attention to the following update or release.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
Message 5 of 8
feldwill
in reply to: dickyshu
Let me know if more input is needed, there are a few other things that will greatly improve ADR.
Message 6 of 8
dickyshu
If we can get some feedbacks related to ADR from your input, that would be great appriciated.
Please do let us know your suggestions and we will record it for futher development.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
Message 7 of 8
I am late to the discussion but we are just now transferring to electronic markups and would like to have an add on for commonly used symbols.  These would be mostly weld symbols.
Any advancement on this?
Thomas Schaefer
Message 8 of 8
dickyshu
Thank you for raise your good suggestion to us.
Currently Design Review did not provide any common used symbols, because these symbols are specified by different domains, with the help of domain engineering applications (ACAD,ACADE,ACADM.ACADMEP...) you will be able to get those symbols and import them to Design Review.
Your suggestion is very good, it needs sometime for us to consider the effort and difficulty to make it come true.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
