Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
How Can You Silently Uninstall ADR?
2 REPLIES 2
MikeCompton
1568 Views, 2 Replies
I need to be able to uninstall ADR 2012 from a command line silently.
In this instance it is 2012, but i expect the command line switches are same/similar for older versions.  The uninstall string is
C:\Program Files\Autodesk\Autodesk Design Review 2012\Setup\Setup.exe /P {9E4D5A41-1051-4F1A-8342-ECB26CA0C86C} /M ADR /language en-US
But that is not silent.
2 REPLIES 2
wube
in reply to: MikeCompton
Please try the command
msiexec /uninstall {9E4D5A41-1051-4F1A-8342-ECB26CA0C86C} /quiet
However,  it haven't been tested.
Ben Wu
SW Engineer
PSEB-GE-ACRD
Autodesk, Inc.
MikeCompton
in reply to: wube
Thanks, much appreciated.
I think i did try that SID but the desktop icon didnt disappear so i assumed it hadnt worked.  A reboot later and further testing confirms the above command works fine, although i have actually setup our package to use:
msiexec /x {9E4D5A41-1051-4F1A-8342-ECB26CA0C86C} /norestart /passive
So if run manually, the technician can see the progress and when run programatically, its hidden from the user anyway, as it runs with the SYSTEM account.
Thanks for your reply.
