Design Review
Design Review
Pstongelitho
Message 1 of 7 (331 Views)
Help Needed. Merged DWFs have wrong characters or annotations
331 Views, 6 Replies
03-29-2012 09:56 AM
Since Design Review 2012 (problem was not present under 2011) and it's new way of merging drawings, the merged file displays wrongfull characters or symbols.
When I open a drawing alone, all the right annotation symbols are displayed properly.
When I merge many drawings in one (using the List view and click and drag method) all the non text symbols are displayed as oblong rectangle.  So all the diameter, surface, perpendicular etc. symbols are only displayed by that rectangle.  The display problem on screen is then carried through printing as well.
We use the merge files to be able to print the drawings for our production department, but with faulty display, printouts are useless.
Thought it might only be a 2012 version problem, but just downloaded the 2013 version and it is still the same.
I am using Windows 7 64 bits.
Anyone have any ideas on how to solve the problem ?
Thank you
Active Member
swiftbim
Message 2 of 7 (325 Views)
Re: Help Needed. Merged DWFs have wrong characters or annotations
03-29-2012 11:09 AM in reply to: Pstongelitho
Do you use the batch print feature from the file menu? You could print multiple individual files using that process.
Pstongelitho
Message 3 of 7 (323 Views)
03-29-2012 11:14 AM in reply to: swiftbim
No I can not use the batch print feature, for some of our drawings are oversize (C or D format) and that feature would not be convenient.  Also the interface is not veryuser friendly.
I merge the files, look if there are any in oversize format, if there are, I take note of the file name, then delete them and then press Print.
Problem is with "merging" the files, which for some reason anihilates all non Letter or number type characters, even the symbols in the drawing template are in error.
Employee
herbert.he
Message 4 of 7 (309 Views)
04-04-2012 10:50 PM in reply to: Pstongelitho
Thank you for reporting this issue.
It's helpful if you can upload dwf/x files (before and after merging) for us to reproduce this issue. Please update test files into our FTP server and let me know the file name(s).
    ftp://files.autodesk.com
    LoginID : simulation
    Password: ADR2009CST
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Pstongelitho
Message 5 of 7 (304 Views)
04-06-2012 06:28 AM in reply to: herbert.he
Hello Herbert,
530 Login incorrect.
Cannot access FTP server to put files in.
Tried many times, LoginID and password are entered as you wrote.
Attached to messages are the files (hopefully it works)
Thank you
Employee
herbert.he
Message 6 of 7 (293 Views)
04-08-2012 08:05 PM in reply to: Pstongelitho
Thank you for your feedback.
It's a known dwfx text font issue. Merging dwf files into dwf format has no this issue, see attached merge.dwf.
Any further question please let me know.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Pstongelitho
Message 7 of 7 (286 Views)
04-10-2012 05:06 AM in reply to: herbert.he
Thank you very much Herbert for your help.
Put default file settings at DWF and problem is solved.
Once again thank you
