Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
File Size
1 REPLY 1
afaust2
773 Views, 1 Reply
File Size
Is there a file size limitation for Design Review? I exported a 3D image from Revit, using the low compressed raster format - the DWF file size is 12 MB.  It works fine until I try to cut a section, then it freezes and closes.  Is there any other way to reduce the size of the file?  I have already limited what is visible in the view, and the section tool works on other models that don't have as much showing.
Thanks.
Tags (2)
1 REPLY 1
loh
in reply to: afaust2
I have same issue, and if i can open the file, i have problems whit Markup tools..??
