Design Review
Member
DGProgrammer
Message 1 of 4 (1,089 Views)
Exception embeeding Autodesk Design Review 2013 in VS2010 C#
1089 Views, 3 Replies
05-04-2012 01:13 AM
I'm working on a Ms Vista x64 system...
I've created a new WinForm C# application (NET framework 4.0 - any cpu).
I've added in Visual studio 2010 toolbox the Autodesk DWF Viewer Control (file located in Program Files\Common Files\Autodesk Shared\DWF Shared\AdView.dll) .
When i drop the control from the toolbar in to a WinForm, Visual Studio hangs with an exception (exc eption code
e0434352). How should I proceed?
Member
vzavec
Message 2 of 4 (949 Views)
Re: Exception embeeding Autodesk Design Review 2013 in VS2010 C#
10-09-2012 08:00 AM in reply to: DGProgrammer
I am facing with the same problem. Did you solved this problem yet? Can you advise me about and please where to find
dwg file open method in API. How to open dwg file with API in C#?
regards, Vojko
Member
DGProgrammer
Message 3 of 4 (940 Views)
10-10-2012 02:56 AM in reply to: vzavec
Sorry, no solution found. Regards, Diego.
Member
rocket4
Message 4 of 4 (841 Views)
10-22-2012 09:50 PM in reply to: DGProgrammer
Try to add that again and again, finally you'll  succeed.
But that's not the end of story. When you compile, VS will crash too.
Luckly you compile successfully, it crashes as soon as you debug.
So ,what you need is more patience Or  VS2008
You are not logged in.
Ask the Community
