Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Design review 2013 will not open dwg files anymore
45 REPLIES 45
Message 1 of 46
9347 Views, 45 Replies
Good morning,
2 days ago I switched to AutoCad LT from inventer (long story). It appears that design review no longer works for me as it does nothing when I try to open up DWG files. I get no error message either.
I have updated trueview, reinstalled both deisgn review and true view to no avail.
Are there any issues between LT and these applications I am not aware of?
Any help would be great
thanks in advance
45 REPLIES 45
Message 41 of 46
m_latz
in reply to: mmanning
Have you checked that for this "current user" the necessary registry keys exists under the HKEY_CURRENT_USER branch ?
regards
Markus
Message 42 of 46
mmanning
in reply to: m_latz
Yes, all the registry entries are as outlined in this thread. No errors, and dwg won't open. Little blue wheel spins for a moment and then nothing. If I run as administrator it works.
[EDIT] to clarify, if I 'run as' a local admin who has the registry information entered in their current user key then I can open DWG files. If I run as a standard user who has the information under current user, not DWG files.
Message 43 of 46
I have attached an updated .reg file for 2016.
Message 44 of 46
Thanks ALL
Tim.West,   thanks for the 2016 verson of the reg file.  I ran it and restarted the pc and it has correct the issue.  I had no problems with the inplementing the fix.
dk
Message 45 of 46
memoalcr
Anyone with the TrueView 2017 version?
Message 46 of 46
m_latz
in reply to: memoalcr
