Hi there - can someone please help. I would like to know how to derive the perimeter of an area I have marked-up?
Thank you for your question.
Please follow the steps below to derive the perimeter of an area of a markup.
1. Use ADR API IAdContent2 to get your markup(s),
IAdContent SectionContent;
MyMarkups = (AdCommon.IAdCollection) SectionContent.get_Objects (2); //2 is to return all markup objects, 3 is to return all selected markup objects....
2. Use IAdContent2 to derive the bounding box of markup(s),
MarkupsExtents = (AdCommon.IAdRect) SectionContent.get_Extents (MyMarkups);
MarkupsExtents.Left;
MarkupsExtents.Top;
MarkupsExtents.Right;
MarkupsExtents.Bottom;
Please refer to the ADR API documentation for more information.
Any further questions please let me know.
Hi, I have the same question as Gedcoull but do not understand Herbert.He's responce.
I have measured areas using the measure area tool to work out floor area, Can I easily convert these area measures into length measures ( i.e. the perimeter of the area) so that I can measure the skirting boards for the rooms i have already measured.
I do not wish to re-click around all my room perimeters when I have already done so.
To claify i am using Autodesk Design Review 2013
Many Thanks & Kind Regards
Chris
