Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Design Review 2013 Installation - Xerces Panic Error
4 REPLIES 4
gitbent67
1058 Views, 4 Replies
I have been using Design Review 2012 with no problems and today I got the notice to update to 2013 Design Review, so I did.  As the installation was running I got an error message "Could not load a transcoding service. Xerces Panic Error".  When the installation finished, I could not run the updated software.  So I uninstalled the software and got the same message while unistalling.  I tried reinstalling after a fresh boot and the same thing happened.  I uninstalled and tried reinstalling Desiogn Review 2012 and had the same results.  I have NEVER had this error message before trying to install Design Review 2013.  Now, I can't run any version of Design Review.  I use this software a lot and it is definitely going to affect my productivity.
I have also tried running a full system scan for viruses, malware, spyware and ran registry cleaning software, then tried a clean install.  Same results.
Can anybody out there help? I've already lost half a day trying to recover from this.
4 REPLIES 4
gitbent67
in reply to: gitbent67
I don't know if it's related, but now my Autocad software is not working right.  I am getting a 'Fail to get CommCtrController!' message and when ever I bring up the properties window, it's completely blank.  THAT never happened before...
herbert.he
Thank you for reporting this issue.
It's not related to Autodesk products, it's a system error. The usual way to get rid of this error is to amend the registry at "HKEY_CLASSES_ROOT\MIME\Database\Charset". You get details from http://www.pcadvisor.co.uk/forums/1/helproom/343572/xerces-panic-error--rebuild-the-registry-tree/.
Hope that helps.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
gitbent67
I am looking into the registry solution. However, Autocad now gives me a 'CommCntrClientSink' error when I open a file. I would post this under a different thread, but I suspect that it could be related.
herbert.he
Thank you for your feedback.
One another discussion group focuses specifically on AutoCAD. I suggest that you can post your question in that group.
Please try the following link for your convenience.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
