PDF is a nice publishing format, if that's all you need.
"Jeff Holloway" wrote in message
news:1107083.1090017092415.JavaMail.jive@jiveforum2.autodesk.com...
> DWF Composer has a sub application that is the DWG Viewer which allows you
to publish to DWF.
> The DWG Viewer application needs two additional functions
> 1) Display on screen in Black and White
> 2) Publish in Black and White
> If these two functions are included into DWG Viewer - then it would be
reasonable to not maintain Voloview as a viable product - otherwise -
Autocad has defeated much of the purpose of the DWF exercise and engineers
like me will simply go back to directing the drafting personel to issue the
drawings in adobe acrobat. Is this what Autodesk is intending to happen?
