I've downloaded the 64-bit verison for AUTODESK DWG TrueView 2014 and started the installation. The process starts, the 'Installing..' bar at the top of the screen progresses to the right in the first 3 -4 minutes. Then it appears to hang. I've rebooted and restarted the installation several times. I've verified that all W7 updates are installed and that no other applications are running. Suggestions?
No. I downloaded from 'Home>Products>Autodesk DWG', then double clicked on the SerupDWGTrueView2014_ENU_64bit.sfx on my machine.
