Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
DWF to DWFx ttf fonts
6 REPLIES 6
dwahlz
816 Views, 6 Replies
When I open a DWF with ttf fonts in it in Design Review (at least versions 2010 and 2011), then save the DWF to a DWFx, all the ttf font turn into rectangles...
This only seems to be the case when working on a 64-bit Vista OS, doing the same on a 32-bit XP system saves to a DWFx correctly.
Does anyone have suggestions on how to convert DWF to DWFx and not loose the ttf font?
Thank you.
6 REPLIES 6
whtank
in reply to: dwahlz
Thank you for your question.
Both DWF and DWFx support embedded fonts; however DWF can also support non-embedded fonts which are just name tag marked this font. If we want to convert DWF to DWFx we need convert these non-embedded fonts to embedded ones. We look for this font from current system through its name. If it cannot be found we will match a best one according to this font’s properties. Indeed some fonts cannot support embedded very well so that leads to something wrong during font converting.
Please upload your DWF file into this thread for us to investigate in more detail
Tank
SW Engineer
PSEB-GE-ACRD-CPG
Autodesk, Inc.
dwahlz
in reply to: whtank
Tank, thank you for your response and looking into this.
I have attached the .dwf that I created from AutoCAD 2008, and I have attached the .dwfx that I saved from the original .dwf through Design Review 2011.
whtank
in reply to: dwahlz
We have found the reason; it is caused by one function from Microsoft used to create the embedded font. I have created a defect in our database to track this issue and started to consult with developers from MS for this issue.
Please let me know if you have any further question.
Tank
SW Engineer
PSEB-GE-ACRD-CPG
Autodesk, Inc.
dwahlz
in reply to: dwahlz
Thank you VERY much Tank!!
Is there a way for me to track the issue to see when it becomes resolved?
Dave
whtank
in reply to: dwahlz
I will try my best to resolve this issue. Once it is fixed by Microsoft or there is any workaround I will let you know.
Tank
SW Engineer
PSEB-GE-ACRD-CPG
Autodesk, Inc.
dwahlz
in reply to: dwahlz
Thanks again Tank!!
