Design Review
Distinguished Contributor
Message 1 of 3 (438 Views)
Accepted Solution
DWF settings when opening a DWG
438 Views, 2 Replies
08-19-2011 06:41 AM
ADR 2012 with companion TrueView 2012.  When opening a DWG file from within ADR, what are the DWF settings TrueView uses?  I am assuming it is a DWF6 ePlot.pc3, but amazingly, I have 18 copies of this file scattered about on my C: drive (most from ADR for different dpi settings (?)).  Opening most of our D-size drawings from within ADR result in DWF files with part of the drawing clipped off, so I need to adjust the plotted margins, but I don't know where to look, or even if these settings are adjustable when using ADR to open DWGs.  DWF, not DWFx.
KState92
Inventor Professional 2014 64 SP1 Update 3
Windows 7 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
*Expert Elite*
pendean
Message 2 of 3 (424 Views)
Re: DWF settings when opening a DWG
08-22-2011 06:00 AM in reply to: kstate92
If you want total control, open the DWG files in TRUEVIEW and set the DWF parameters and create them from there: I believe DVR simply uses whatever settings are existing in the pagesetup and simply redirects to the DWF driver.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Message 3 of 3 (420 Views)
08-22-2011 06:30 AM in reply to: pendean
I'll give that a try, Thanks.
I see they still haven't fixed the filter papers bug regarding the un-deselectable ISO Full Bleed B1 paper size; no rush, Autodesk.
KState92
Xeon E5-1620
16 GB Ram
Quadro 4000
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
