Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
DWF's in the Cloud
2 REPLIES 2
BobbyC.Jones
818 Views, 2 Replies
DWF's in the Cloud
We're taking the plunge and moving into the world of VDI.  A snag we've hit is printing DWF files.  On average each of our sheets spools 5MB to the printer when printing.  Our average set contains between 60 and 80 sheets.  To print a single plan we're spooling 300 to 400MB over an internet connection.  Considering that only a portion of the pipeline is dedicated to print jobs, this becomes a big problem.  We've tried formats other than DWF, PDF and XPS, but they spool even more data to the printers.  Our current work around is to print sheets individually as needed or printing entire sets during lunch breaks.
Does anyone have any experience or thoughts on how to handle this situation?  Thanks!
Bobby C. Jones
2 REPLIES 2
whtank
in reply to: BobbyC.Jones
Thank you for your question.
Autodesk Design Review supports some ways to reduce spooling size of printing. Please follow these steps to print your DWF/x files:
  1. Open your DWF/x file with Autodesk Design Review 2011.
  2. Click ‘Print’ button from Ribbon or press ‘Ctrl+P’ to show print dialog.
  3. Select a proper printer and click ‘Advanced…’ button on this dialog.
  4. Choose lower resolution from ‘User defined’ combo box.
  5. Choose ‘Low’ option from Color Quality tab.
  6. Click OK and print.
Last I would like to know what kind of geometry data are mainly in your sheets, gradient geometries, raster data or normal geometry data. What paper size are you mainly using?
Tank
SW Engineer
PSEB-GE-ACRD-CPG
This seems to be an issue across most disciplines. A quick solution is to download your file from the cloud  print locally.
