Design Review
*Sergio
Message 1 of 8 (429 Views)
DWF Printer Driver
429 Views, 7 Replies
08-02-2004 03:31 AM
Hi there I was trying to compose a file with an Autocad drawing and i wanted to insert a word file into a dwf file. Is this possible? Like in pdf writer, you can insert a pdf in another pdf. Does composer makes this too? Thanks
*Scott Sheppard
Message 2 of 8 (429 Views)
Re: DWF Printer Driver
08-02-2004 07:29 AM in reply to: *Sergio
DWF Composer allows you to combine DWFs, Docs, and other file types into a single DWF. "Sergio" wrote in message news:410e17dc$1_3@newsprd01... > Hi there > I was trying to compose a file with an Autocad drawing and i wanted to > insert a word file into a dwf file. Is this possible? Like in pdf writer, > you can insert a pdf in another pdf. Does composer makes this too? > Thanks > > > >
*David Metcalf
Message 3 of 8 (429 Views)
08-02-2004 08:58 AM in reply to: *Sergio
Drag and drop from Windows Manager. "Scott Sheppard" wrote in message news:410e4fba$1_1@newsprd01... > DWF Composer allows you to combine DWFs, Docs, and other file types into a > single DWF. > > "Sergio" wrote in message news:410e17dc$1_3@newsprd01... > > Hi there > > I was trying to compose a file with an Autocad drawing and i wanted to > > insert a word file into a dwf file. Is this possible? Like in pdf writer, > > you can insert a pdf in another pdf. Does composer makes this too? > > Thanks > > > > > > > > > >
*Sergio
Message 4 of 8 (429 Views)
08-03-2004 01:25 AM in reply to: *Sergio
Im sorry but i dont seem to get thta to work. If i drag and drop another DWF inside and open DWF it just replaces it. Word, powerpoint, pdf files just give errors. the message says An erro occured while opnening the file Can someone help me? thanks "David Metcalf" wrote in message news:410e64b5_1@newsprd01... > Drag and drop from Windows Manager. > > "Scott Sheppard" wrote in message > news:410e4fba$1_1@newsprd01... > > DWF Composer allows you to combine DWFs, Docs, and other file types into a > > single DWF. > > > > "Sergio" wrote in message > news:410e17dc$1_3@newsprd01... > > > Hi there > > > I was trying to compose a file with an Autocad drawing and i wanted to > > > insert a word file into a dwf file. Is this possible? Like in pdf > writer, > > > you can insert a pdf in another pdf. Does composer makes this too? > > > Thanks > > > > > > > > > > > > > > > > > >
*Carolyn Kreisel \(Autodesk\)
Message 5 of 8 (429 Views)
08-03-2004 07:04 AM in reply to: *Sergio
Sergio, If you wish to insert a Word file into a DWF, you first need to create a DWF from the Word file using the free DWF Writer. 1- Install the DWF Writer: http://www.autodesk.com/dwfwriter 2- Open the file in Word and select Print. 3- Select "Autodesk DWF Writer" as the printer name. 4- Select OK and create a DWF file. 5- Open the DWF in Composer that you want to add the Word file to. 6- Drop the DWF you created in step 4 onto the List or Thumbnail tab of the Navigator. I hope this answers your question. -Carolyn "Sergio" wrote in message news:410f4bd5_3@newsprd01... > Im sorry but i dont seem to get thta to work. > If i drag and drop another DWF inside and open DWF it just replaces it. > Word, powerpoint, pdf files just give errors. the message says An erro > occured while opnening the file > Can someone help me? > > thanks > > > "David Metcalf" wrote in message > news:410e64b5_1@newsprd01... > > Drag and drop from Windows Manager. > > > > "Scott Sheppard" wrote in message > > news:410e4fba$1_1@newsprd01... > > > DWF Composer allows you to combine DWFs, Docs, and other file types into > a > > > single DWF. > > > > > > "Sergio" wrote in message > > news:410e17dc$1_3@newsprd01... > > > > Hi there > > > > I was trying to compose a file with an Autocad drawing and i wanted to > > > > insert a word file into a dwf file. Is this possible? Like in pdf > > writer, > > > > you can insert a pdf in another pdf. Does composer makes this too? > > > > Thanks > > > > > > > > > > > > > > > > > > > > > > > > > > > >
*Sergio
Message 6 of 8 (429 Views)
08-05-2004 04:55 AM in reply to: *Sergio
It works now...i think i had an older version of dwf writter Thanks "Carolyn Kreisel (Autodesk)" wrote in message news:410f9b8e$1_1@newsprd01... > Sergio, > > If you wish to insert a Word file into a DWF, you first need to create a DWF > from the Word file using the free DWF Writer. > > 1- Install the DWF Writer: http://www.autodesk.com/dwfwriter > 2- Open the file in Word and select Print. > 3- Select "Autodesk DWF Writer" as the printer name. > 4- Select OK and create a DWF file. > 5- Open the DWF in Composer that you want to add the Word file to. > 6- Drop the DWF you created in step 4 onto the List or Thumbnail tab of the > Navigator. > > I hope this answers your question. > -Carolyn > > > "Sergio" wrote in message news:410f4bd5_3@newsprd01... > > Im sorry but i dont seem to get thta to work. > > If i drag and drop another DWF inside and open DWF it just replaces it. > > Word, powerpoint, pdf files just give errors. the message says An erro > > occured while opnening the file > > Can someone help me? > > > > thanks > > > > > > "David Metcalf" wrote in message > > news:410e64b5_1@newsprd01... > > > Drag and drop from Windows Manager. > > > > > > "Scott Sheppard" wrote in message > > > news:410e4fba$1_1@newsprd01... > > > > DWF Composer allows you to combine DWFs, Docs, and other file types > into > > a > > > > single DWF. > > > > > > > > "Sergio" wrote in message > > > news:410e17dc$1_3@newsprd01... > > > > > Hi there > > > > > I was trying to compose a file with an Autocad drawing and i wanted > to > > > > > insert a word file into a dwf file. Is this possible? Like in pdf > > > writer, > > > > > you can insert a pdf in another pdf. Does composer makes this too? > > > > > Thanks > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Member
Message 7 of 8 (429 Views)
09-28-2004 01:56 PM in reply to: *Sergio
There is not a way to use AutoCAD's publish command to do this without purchasing the DWF Composer as well, is there?
Valued Contributor
Message 8 of 8 (429 Views)
10-03-2004 12:41 PM in reply to: *Sergio
Sergio,
Caroline's instructions apply to non-Autodesk applications where you're trying to create DWF files. If you're working within AutoCAD or other Autodesk applicaitons like Revit, ADT, Inventor, then you do have built-in capabilities to publish DWF out of those native files. However, for applications like Word or Excel, you'll need to use the DWF Writer.
Doug Look, Product Manager
Autodesk, Inc.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
