Design Review
Active Member
bdr5843
Message 1 of 5 (389 Views)
DWF Converter Error
389 Views, 4 Replies
10-08-2011 04:37 PM
Hi, there.
I am having problems trying to open an .dwg file in Design Review 2011. The drawing was developped in Civil 3D 2009 (installed in my computer). In my computer i have both, Design Review an Drawing True View 2011 installed, but when i try to open the drawing (.dwg file) in Design Review 2001 I receive the following message: " DWF Converter Error. Problems encountered durind dwf import".
In other instances Design Review 2011 open a blank file.
Can anybody help me solve this problem?
Thanks a lot.
Benjamin
Employee
Message 2 of 5 (385 Views)
Re: DWF Converter Error
10-08-2011 08:11 PM in reply to: bdr5843
Hi Benjamin,
Thank you for posting.
Could you please attach the drawing file you use? It is good to get the drawing file for us to investigate the issue.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Active Member
bdr5843
Message 3 of 5 (379 Views)
10-09-2011 04:17 AM in reply to: bdr5843
Thanks for your reply.
Atached please find de drawing file .
Benjamin Delgado
Employee
Message 4 of 5 (369 Views)
10-09-2011 11:37 PM in reply to: bdr5843
Do you have AutoCAD installed on your computer? If AutoCAD and DWG Trueview co-exist on your machine, ADR will use AutoCAD to import DWG file.
Using the file you attached, I could NOT reproduce the error you met. However, the drawing file becomes to blank(no content) after imported into ADR 2011 on my test machine, this should be a defect of special files.
If you need to use ADR to view this drawing, I suggest you open it directly in DWG Trueview, then export/publish it to DWFx, and then open it in ADR.
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Active Member
bdr5843
Message 5 of 5 (367 Views)
10-10-2011 07:12 AM in reply to: dickyshu
Thanks a lot for your help.
Yes, I do have Civil 3d 2009 software installed in my computer (which also contain Acad 2009). If you find the solution to this issue, I would appreciate let me know.
In the other hand, I used  your recommended procedure and it worked for me very well. At least this is an alternate solution.
Benjamin Delgado
You are not logged in.
Ask the Community
