I printed a project to .dwf combining 10 sheets. When I open the file in DR, all of the thumbnails show, the first sheet is open in the main editing window, and I am unable to open any other sheets, Tried re-printing twice, no change.
Can't open the help file either. Tried using the slideshow arros in the upper right and nothing happens there either.
Gues I'l uninstal-re-install unless I hear of a better fix??
When I upload the file to 360 I'm getting-
"The document you are trying to view was not processed completely. There might be a server problem at this time. Or you may be using a corrupt file or invalid format. Try re-uploading the file to remedy the issue."
I've actually uploaded 2 different .dwf projects to 360. One done in Revit architecture 2009 from my pc, and 1 done in Revit Architecture 2012 from my laptop and I'm getting the same message, (see last post), when I try to view them or open them in 360.
unless you can share the DWF(s) here, about the onlybguess would be you created incomplete DWFs.
