Am having problems closing ADR2011. It just won't close properly, have to right click on Taskbar tab and close from there, where it tells me that the program isn't responding, etc .... and eventually sends an error report.
Cheers,
Pete B.
Thank you for your report.
Do all of your DWF files have this problem? If not, please attach the file which you experience this issue for us to do more investigation.
Definitely all the files I've been using recently,but that's prob only 3-4 files.
FYI, I'm running Win XP (x86) with Acad09 & 11 installed. I'm fairly sure it hasn't always been like this, but since I only use it occasionally, for mark-ups, I'm not exactly sure at what point this behaviour started. May well have been around the time I was having problems with saving as .pdf (transparency issue), at which point I d/loaded & installed the hotfix and eventually got in to export OK.
Cheers,
Pete B.
Thank you for reporting this issue.
It's a known issue of Autodesk Design Review and will be considered for possible fixed in future releases.
Please let me know if you have any further questions.
