Design Review
New Member
Message 1 of 3 (2,710 Views)
Can't install Design Review in any WinXP 32
2710 Views, 2 Replies
04-05-2012 02:31 AM
I tried, in the last 4 weeks, to install Design review in severall computers running Windows XP 32 bits.
I have allways the same error - Internet connection problems. That's not true.
I can't install in any of them.
In my machine, with Win7 64 was installed with no error, at the first time.
Attached is the error.
Message 2 of 3 (2,698 Views)
Re: Can't install Design Review in any WinXP 32
04-06-2012 05:26 AM in reply to: eluis2012
Sorry this reply is of no assistance only complaint of similar problem but on a Win7 64 bit version.
I had previously sucessfully installed ver 2011 and 2012 on the same machine.
When I started the program (2012) it notified me of upgraded version (2013) being available for download, to which I assented to the upgrade. Following the uninstall 2012 portion it choked when attempting the download of 2013 telling me I had no Internet connection, which was wrong on all counts.
It matters not how I attempt to install the 2013 version, from fresh boot up or not it balks with the same error message.
So here I sit with NO version installed for use and looking for a solution as well!
Any help appreciated!
Paul
Message 3 of 3 (2,694 Views)
04-06-2012 09:52 AM in reply to: eluis2012
As typically happens, when checking a drawing for 30 mins, the errors become obvious the moment you push the print or send button...
I figured I'd download the package and install it directly since I was doing a stand alone.
Apparently I authorized installation of the Download Mgr on my computer.
I was unable to download the package at all. I finally deduced the Download Mgr may be the problem and disabled it from my MS Explorer 9. Download problem went away. So for whatever reason, Win 7 64 bit, Explorer 9, incompatability whatever. Downloaded the package (>700MB) and it installed successfully.
Things are working again.
Everyone with similar systems may wish to check for and disable Download Mgr to see if this helps...
Paul
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
