This is still happening.
If a user opens a pdf file in ADR from a location that is read only, and then attempts to markup this pdf and save it as a dwf the resulting dwf file is 0-2kb in size.
If any user attempts to open that dwf file, the software will crash (errors listed above) and it takes an entire uninstall/reinstall of ADR.
We have multiple users experiencing this issue, and our work around is to copy the file to a location that the user can edit, and then mark up the file. That's not a work around that we can do forever. All it takes is one user forgetting that they can't markup a read only file (even if they open it as read only, mark up then 'save as' and try to save to an editable location, the resulting dwf file is still corrupted....and the next person that opens that dwf file will crash their software too, to the point it requires a full uninstall/reinstall).
Attached is the dmp file...renamed to txt since it appears that .dmp files are not accepted on here.
Today the user copied a 10 page pdf file to an editable location.
User went to windows explorer, right clicked on the editable file, open - autodesk
The file opened just fine.
User tried to print the file, and it gave those error messages posted previously.
Attached are the dump files.
Thank you for reporting this issue.
Please follow the steps below to solve this issue.
1. Start the Windows Registry Editor (regedit.exe) and perform the necessary steps for your operating system.
On XP computers,
2. Navigate to "HKEY_CURRENT_USER\Software\Autodesk\Design Review\Preferences\MRUList\" and delete all these 'MRL*' entries.
On Vista and Windows 7 computers,
2. Navigate to "HKEY_CURRENT_USER\Software\AppDataLow\Software\Au todesk\Design Review\Preferences\MRUList" and delete all these 'MRL*' entries.
3. Exit the Registry Editor.
Please let us know if these worked for you.
I'm getting the same message, when trying to open "read-only" drawings. I only have the free download of the viewer and Design Review (2010) and only some files get this message.
I deleted the MRL files as listed about, but it does not change the message? Could it be the files themselves that are corrupt (they do not belong to me, I am accessing them off of a directory website) or is it the Design Viewer software?
I appreciate your help!
Several of our machines just started getting a similar message this afternoon, 2 Win7x64 boxes and 1 XP box. One of the DWF files was corrupted after closing DR. I'm checking with our IT group to see if they pushed out any software updates.
The only thing that has seemed to help is something that we received from our reseller: Right mouse click on the dwf file from a explore window and choose open with internet explorer (must be ie7 or higher) .
This seems to be the alternate to opening the file directly.
I also told them to stop using ADR for printing PDF's, as that was another cause to the crashing.
Just make sure to tell your people to look at the file size of the dwf before attempting to open. Anyone that attempts to open a dwf file that is 0-4kb in size, it will crash their ADR also, and you will have to do the clean uninstall/reinstall to get both work stations running.
I'm curious to when the other people that have reported this when they installed their ADR (after release) the first time around. We went for almost 2 months before the problem appeared....
Hi ssnead123,
What's the message you got?
Is it "Your current version of Design Review does not support files of this type"? Or messages that pkimmons posted above?
There're different issues. My reply above was for the later.
Hi Jones,
Can you send me that corrupted DWF file for further investigation?
I would except they are ITAR files, so we would have to go thru a bunch of steps to get clearance. It is recreatable with any PDF that is opened from a read only location on the network by using the double click in Windows Explorer.
