Find and Zoom Using Visual Basic
Message 1 of 12
I am trying to get AutoCAD to bring up a drawing or set of drawings and then use the Edit-->Find command to find a certain text string in the drawing and Zoom to it. Then I will be using a third party program to take a snapshot of the screen. This will be done multiple times to find multiple rooms within a drawing or set of drawings. I am looking at automating this using Visual Basic or Visual Basic For Applications.
My question is on the "Find and Replace" dialog box, how can I put information in the textbox for the "Find text string:" prompt and then have the system press some buttons. I want to do this all from VB or VBA without any user intervention. Is this possible at all and if so any ideas/hints on how I can do it?
Replies (11)
Message 2 of 12
Create a SelectionSet
I
how I can do it?
Message 3 of 12
Could you give me any more details?
Message 4 of 12
I do NOT see how this could work..................!?!?!?
Message 5 of 12
If the text you're trying to find is in model or paper space and
it is the entire contents of the text entity (as opposed to only
a portion of it) you only need to use a selection set to locate it
(using a filter with the entity type set to "TEXT", and dxf code 1
for the text).
If you're trying to do a case-insensitive search or the text you're
trying to find is only a portion of the entire text entity's contents,
or it is in MTEXT, then it becomes a bit more involved. A selection
set filter with a wildcard can work for regular text, but for MTEXT
there are formatting codes to deal with.
A solution that can deal with any aforementioned case
is the TextProcessor class in AcadX, which you can find at http://www.caddzone.com/acadx
"rfrenter" wrote in message news:[email protected]...
Message 6 of 12
I have a small program to do this, if you'd like I
can e-mail it to you and you can tweak it to suit your needs.
  Jacob Dinardi
I
how I can do it?
Message 7 of 12
just run the code in vba put text to find in
textbox1
put text to replase in txbox2 an run
it
I
Message 8 of 12
post the code
I can e-mail it to you and you can tweak it to suit your needs.
  Jacob Dinardi
I
how I can do it?
Message 9 of 12
That would be great Jacob. Thanks..................
Message 10 of 12
 okay post the code
LHGO
That
Message 11 of 12
There is not a whole lot to it, so I figured I'd
just post the code. You should be able to paste all this into a module and run
it, the program does expect there to be a layer named "B" - you should be able
to find and edit it. Fair warning this was an early attempt at acad vba, so it
could use some optimizing I'm sure. With that said, here ya go, and watch out
for word wrap...
Option Explicit
Dim oSS As AcadSelectionSet
Dim oEnt As
AcadEntity
Dim RemObj() As AcadEntity
Dim oLayer As AcadLayer
Dim
bLayers() As Boolean
Dim sFind As String
Dim i As Integer, j As
Integer
Dim fType(0) As Integer, fData(0) As Variant, Pt() As
Variant
Public Sub Run_FindBOM()
  On Error Resume
Next
  'Isolate layer B
  IsolateLayers
ActiveDocument.Layers("B").LayerOn = True
  'Create the
selection set
  MakeSelSet
  'Get the letter to
find
  sFind = ActiveDocument.Utility.GetString(False, "Enter the mark
to find: ")
  'Remove all non-matches
  i = oSS.Count
j = 0
  For i = 0 To oSS.Count - 1
    If
oSS.Item(i).TextString <> sFind Then
ReDim Preserve RemObj(j)
      Set RemObj(j) =
oSS.Item(i)
      j = j + 1
  Next
  'Get rid of all the items that don't
match
  oSS.RemoveItems RemObj
  'Report matches
found and zoom to each
  If oSS.Count Then
    If
MsgBox(oSS.Count & " matches found. Do you want to see them?", vbYesNo) =
vbYes Then
      'Restore the previous layer
states
      For i = 0 To
ActiveDocument.Layers.Count - 1
ActiveDocument.Layers(i).LayerOn = bLayers(i)
Next
'Create the array of text insertion points
ReDim Pt(oSS.Count)
      j =
0
      For Each oEnt In
oSS
        Pt(j) =
oEnt.InsertionPoint
        j = j +
1
      Next
      Application.ZoomCenter Pt(LBound(Pt)), (5 *
ActiveDocument.GetVariable("DIMSCALE"))
      For i = LBound(Pt) + 1 To UBound(Pt) -
1
        If
UCase(ActiveDocument.Utility.GetString(False, "View next (Y/N)? ")) <> "Y"
Then Exit For
Application.ZoomCenter Pt(i), (5 *
Next
  Else
    'No
matches were found
    MsgBox "No balloons matching """ &
sFind & """ were located."
CleanUp
  Exit Sub
ERRTRAP:
ActiveDocument.SelectionSets("SSFIND").Delete
    For i = 0 To
Next
    CleanUp
End
Sub
Private Sub IsolateLayers()
  'Store the
current layer state of each layer in the drawing
  For i = 0 To
    ReDim Preserve
bLayers(i)
    bLayers(i) =
ActiveDocument.Layers(i).LayerOn = False
  Next
End Sub
Private Sub MakeSelSet()
  On Error Resume
Next
ActiveDocument.Utility.Prompt "Select all balloons: "
  Set oSS =
ActiveDocument.SelectionSets.Add("SSFIND")
  fType(0) = 0: fData(0) =
"TEXT"
  oSS.SelectOnScreen fType, fData
End Sub
Sub CleanUp()
  Set oSS = Nothing
Set oEnt = Nothing
  Set oLayer = Nothing
  Erase
bLayers
  Erase fType
  Erase fData
  Erase fType
End
Sub
That
Message 12 of 12
   Dim oText
As AcadText
    Dim vvar1 As
Variant
    ActiveDocument.Utility.GetEntity oText, vvar1,
"Select a 'TEXT': "
    oText.TextString =
"test1"
End Sub
for word wrap...
Option Explicit
Dim oEnt As
AcadEntity
Dim
Dim sFind As String
Integer
Variant
  On Error
Resume Next
  'Isolate layer B
IsolateLayers
  'Create the selection set
  MakeSelSet
'Get the letter to find
  sFind =
ActiveDocument.Utility.GetString(False, "Enter the mark to find: ")
  i = oSS.Count
  j = 0
  For
    If oSS.Item(i).TextString
<> sFind Then
      ReDim Preserve
RemObj(j)
      Set RemObj(j) =
oSS.Item(i)
      j = j + 1
  Next
match
  'Report matches
  If oSS.Count Then
    If
vbYes Then
states
      For i = 0 To
bLayers(i)
Next
ReDim Pt(oSS.Count)
      j =
0
      For Each oEnt In
oSS
        Pt(j) =
oEnt.InsertionPoint
        j = j +
1
      Next
1
        If
"Y" Then Exit For
Next
  Else
    'No
matches were found
& sFind & """ were located."
  CleanUp
  Exit Sub
ERRTRAP:
    For i = 0
To ActiveDocument.Layers.Count - 1
Next
    CleanUp
End
Sub
  'Store the
  For i = 0 To
    ReDim Preserve
bLayers(i)
    bLayers(i) =
  Next
End
Sub
  On Error
Resume Next
  Set oSS =
"TEXT"
End Sub
Sub CleanUp()
  Set oSS =
Nothing
  Set oEnt = Nothing
Erase bLayers
  Erase fType
  Erase fData
  Erase
fType
End Sub
That
