For the visualization of different files are created.
In an update queue (job server) or when migrating the DWF generated by the Apprentice, see Appendix "Created Apprentice".
When files are checked out properly stored and checked back in a DWF file is generated, see Appendix "Created Inventor".
DWF files, which are created by the Apprentice (Job Server), open the Vault (or design review) right on the front view.
It is not possible to reach with the click of the small house in the isometric view.
However, the DWF is created by local Inventor at check-in, then looks at the DWF as ever, namely in the stored isometry.
In the meantime, we have a third result:
If the DWF created by the Task Scheduler, then the IAM and IPT are almost right again. However, the IAM's open in the front view, with the click of the small house the view changes to the isometry.
Is there nobody with the same problem?
