Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
ADR installing error message
1 REPLY 1
gustavo_c_vasconcellos
599 Views, 1 Reply
I have been trying to install ADR 2012 and I always receive error message.
I run on Window 7 Professional and 64 bits
I have running (with no problems) Revit 2012, Robot 2012, and Autocad 2012
I had already tried the following:
- install from the website
- download and install from the computer
- download the bundle and install from the computer
- uninstall Akami and tried again..
Attached you find the log and error message
Gustavo Vasconcellos
1 REPLY 1
Thank you for your question.
According to the log file, your problem may be caused by Microsoft Visual C++ 2010 Redistributable (x86) upgrading. We are handling this problem.
You can work around this problem by remove Microsoft Visual C++ 2010 Redistributable (x86) from Control Panel->Add or Remove Programs. Then restart the installation process.
Ben Wu
SW Engineer
PSEB-GE-ACRD
