Design Review
Employee
Message 71 of 153 (3,412 Views)
Re: ADR 2012 installation issue collection
05-12-2011 08:17 PM in reply to: MaxviewTV
Thank you for your feedback.
For Windows & 64bit system, the cache folder is C:\Program Files (x86)\Common Files\Akamai\Cache\.
The installer will install the Akamai NetSession Interface in your computer, then download required components for Design Review by Akamai Interface, and install components automatically at last.
So please make sure you have uninstalled the Akamai Netsession Interface, and then run the installer.
If you still fail to install VC++ component by these steps, please try to find out the component in cache folder and install it manually, then try the installer application again.
Ben Wu
SW Engineer
PSEB-GE-ACRD
Autodesk, Inc.
MaxviewTV
Message 72 of 153 (3,401 Views)
05-13-2011 08:50 AM in reply to: wube
Hi Ben,
Still no luck. I tried the uninstall and reinstall and it still did not work. Then I tried to install the VC ++ manually from the Cache folder and got the same error message as when I try to install the ADR 2012 package.
Attached is the screen shot of when the manual install failed.
Thank you again.
New Member
Fragbert
Message 73 of 153 (3,351 Views)
05-25-2011 01:46 PM in reply to: dickyshu
I just want to point out how profoundly STUPID the Design Review 2012 install routine is set up to check for the requisite Visual Studio runtimes.
The installer is fatally flawed in that the .MSI only allows the installation to continue if the INITIAL RELEASES of 2005, 2008 and 2010 runtimes are present - and WILL NOT install if you have (wisely) installed the latest updated versions from microsoft (which are pushed down and available from windows update). All three runtimes have updated versions released as critical updates from Microsoft, dated this year (2011).
So in order to automate an unattended install of this package, I first have to install the horribly outdated original runtimes, run the autodesk installers, then run the updated runtime installers to ensure the PC is not left with a gaping security hole. What a waist of time!
FYI - the latest versions of the required runtimes (that I suggest everybody install if you have not already) are:
KB2467175 for 2005 runtimes
KB2467174 for 2008 runtimes
KB2467173 for 2010 runtimes
These are not "patches" per se, they are complete, stand alone full versions of the runtimes.
Valued Contributor
Message 74 of 153 (3,326 Views)
05-26-2011 03:12 PM in reply to: johnsoap
This did not work for me. And since I can't see any difference between ADR 2012 and ADR 2011, apart from this problem in 2012, I decided to go back to 2011. However I can't find it??????
Employee
Message 75 of 153 (3,322 Views)
05-26-2011 07:21 PM in reply to: Projectmax1
Thanks for trying ADR 2012, you can view the difference in what's new:
http://images.autodesk.com/adsk/files/adr2012_readme.htm
Here you are the ADR 2011 download link if you're going to revert back:
http://usa.autodesk.com/adsk/servlet/pc/item?id=16402480&siteID=123112
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
MaxviewTV
Message 76 of 153 (3,313 Views)
05-27-2011 05:54 AM in reply to: dickyshu
Hi Dicky,
I'm not even able to install the 2011 version so I'm going back to 2010 which worked perfectly for me. However, I'm only able to open and read DWF files but not DWG files from the 2010 version for some reason. Any suggestions of what to do so that I can at least open and read a DWG file?
Thank you.
Employee
Message 77 of 153 (3,292 Views)
05-30-2011 06:32 PM in reply to: MaxviewTV
ADR cannot view DWG file independently. In order to open a DWG file with ADR 2010, you need to install the same version of DWG View tools (AutoCAD 2010 or DWG Trueview 2010).
-Dicky
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
MaxviewTV
Message 78 of 153 (3,285 Views)
05-31-2011 03:06 AM in reply to: dickyshu
Thank you, Dicky. I'll give it a try.
Member
JonRE
Message 79 of 153 (3,242 Views)
06-07-2011 10:46 AM in reply to: jandrews407
I can't install Autodesk 2012 on Windows XP SP3 from the downloaded executable.  It fails and gives me the error which I have attached.  I also included log files.
Member
cpulsoni
Message 80 of 153 (3,218 Views)
06-09-2011 01:28 AM in reply to: dickyshu
when i try to install ADR12 I have this error msg. Please can you help me to resolve it?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
