Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
ADR 2012 - font problem when merging single sheet DWF files into multi-sheet DWF
2 REPLIES 2
612 Views, 2 Replies
Greetings all,
This morning I had a peculiar problem with 2012 ADR. I plotted 12 single sheet DWF files (easier than using the publish command as they are generated from several drawings in Civil 3D 2012 x64) then attemped to merge them into a single, multi-sheet DWF. Once merged, some of the text defaults to "blocks" (literally "rectangles"). The fonts that are embedded are arial and I am not familiar with a single windows based system that does not have this loaded by default. The single sheet DWF files display the text correctly (see attached).
I am completely perplexed. I am running window 7 x64.
Respectfully,
Jason Biagio
2 REPLIES 2
herbert.he
Thank you for reporting this issue.
How did you merge those DWF files into a multi-sheet file? By drag and drop or other special tool?
Please provide us the single sheet DWF file for us to investigate.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
in reply to: herbert.he
Herbert,
I think I may have solved the problem. The single sheet DWF files automatically replaced "missing" fonts but lost this ability once I dragged and dropped them into the ADR window to create a multisheet DWF. I have since updated the fonts (verified that Arial was used) and now they merge with no ill effects. Thank you for your attention in the matter.
Respectfully yours,
Jason Biagio
