Hello
I recently revceived my new laptop to be used to showcase new designs in meetings etc, i've come upon a problem tho.
Every time i open one of the latest designs, it opens up fine, loads everything, but once i start moving it ADR just closes, no messages no nothing. Any ideas?
System is
Dell 15z
i7 2620M
Nvidia GT525M
8gb RAM
240GB Corsair series 3 SSD
Thank you for reporting this issue.
Please attach a file which can reproduce this issue for us to investigate.
Hi anriil,
It should be a preformance issue. You can take advantage of better 3D model performance by changing below options:
1. Change Driver to Direct3D on "Model" tab of Options dialog.
2. Drag the scroll bar to the end of "Performance".
Hope that helps.
Hello
Changed those, no change, this time it showed the "...forced to close" dialog. Sent in 4 error reports, maybe you can take a look at those.
