Design Review
Board Manager
Message 11 of 73 (5,635 Views)
Re: ADR 2011 - Suggested Fixes for Installation-Related Issues
04-29-2010 07:40 PM in reply to: cblocher
Thanks for that feedback. So often we at Autodesk forget that the old DWF Viewer, the predecessor to Design Review, is still in the wild.
We typically only tell people to uninstall previous versions of Design Review.
We should amend that recommendation, adding that DWF Viewer should also be looked for on customer systems and uninstalled before installing new versions of Design Review.
Very good info.
Thank you!
Chris Blocher
Principal Learning Content Developer
Cloud Platforms
Member
Message 12 of 73 (5,634 Views)
04-30-2010 08:48 AM in reply to: cblocher
Hi There,
I appreciate download suggestions. I tried both versions but recieved failure to install messages. I have attached the log file from my attempt, in case it helps. It won't allowed two attachments so i'll send another post with the error messages.
Member
Message 13 of 73 (5,635 Views)
04-30-2010 09:08 AM in reply to: cblocher
...or not because I can't make the file small enough... the jist of the errors was "Error 2753.The File '.....' is not marked for installation.
New Member
Entropym
Message 14 of 73 (5,604 Views)
06-28-2010 02:50 PM in reply to: cblocher
I did the entire procedure as shown in message 2 but I still get the "Autodesk Design Review 2011 (0x643 Internal Error)" message after it tries installing for a few moments.
Interestingly, none of the registry keys that I was supposed to delete were present.
Windows XP pro 2002 SP3.
Mickey Morgan
New Member
Entropym
Message 15 of 73 (5,603 Views)
06-28-2010 03:30 PM in reply to: Entropym
I followed the suggestion to remove the Microsoft Visualbasic programs but Design review put them back and the installation failed again.
I bailed and went to 2010 which is still an upgrade from where I was previously. That installation worked. I'll wait until the 2012 version as I don't want to spend more time on 2011.
Active Contributor
Message 16 of 73 (5,560 Views)
07-07-2010 12:20 PM in reply to: cblocher
Very helpful post. My Design Review 2011 install was failing and uninstalling Design Review 2008 was throwing a "Fatal Error." The first set of instructions didn't help, but the second "complete removal" procedure did.
thanks much.
Jason Rossitto
Beth Israel Deaconess Medical Center
Message 17 of 73 (5,510 Views)
07-16-2010 04:56 AM in reply to: cblocher
Same here, on Vista Business X64 (german). Tried everything but this **** thing just won't install. (Why am I not surprised?)
Error 1603
Member
Falthor
Message 18 of 73 (5,483 Views)
07-21-2010 06:55 AM in reply to: cblocher
  major install issue.
  When I went to install design review 2011 (upgrade reccomended from the program itself) everything went fine till the very end of the install where it crashed, I've attached the install log.
  At this point I cannot install Design Review 2011, or 2010 (screen shots of the errors I get when I try to do 2010 attached).
  I need this program to markup window layouts for work, and without it am basically stuck.
  It seems that the registry key are locked, and I can't even access them to delete or remove.  Help?
Message 19 of 73 (5,483 Views)
07-21-2010 08:14 AM in reply to: Falthor
If you are not able to delete the keys, then you are trying to install as a user that is not an admin.
Must be admin to install.
Member
Falthor
Message 20 of 73 (5,481 Views)
07-21-2010 11:25 AM in reply to: cblocher
I am the only user on this computer and yes I am setup as an admin.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
