XREF Control
XREF Control
thomk
XREF Control
thomk
Is there a way to manually call up the XREF dialog box?
The 2012 version does not appear to allow you to call it up.
When loading a file that has an xref issue, the pallette will appear if the user tries to resolve the XREF issue.
Thank you,
t.k.
From application menu , type xref in the search command field as shown in attached screenshot.
thomk
Thank you!
I hadn't noticed that's what that field was for.
Thank you again!
you are welcome.
whitney_jeff
My XREF palette disappeared and typing XREF does not start it,  I have not been able to find anyway to bring it back - any help would be appreciated!
I am right now stuck using the classic version dialogue box which is clunky at best 😔
whitney_jeff
Got it!
Thanks Dean
