Is there a way to manually call up the XREF dialog box?
The 2012 version does not appear to allow you to call it up.
When loading a file that has an xref issue, the pallette will appear if the user tries to resolve the XREF issue.
Thank you,
t.k.
Solved by Zeinab1985. Go to Solution.
From application menu , type xref in the search command field as shown in attached screenshot.
Thank you!
I hadn't noticed that's what that field was for.
Thank you again!
My XREF palette disappeared and typing XREF does not start it, I have not been able to find anyway to bring it back - any help would be appreciated!
I am right now stuck using the classic version dialogue box which is clunky at best 😔
