DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Windows 7 Compatibility
2 REPLIES 2
terry_kesteloot
774 Views, 2 Replies
I'm getting an error message on install that Treuview is not compatible with Windows 7. Is this a bogus error message? If so is there a way around it? If not is there a release date for the 64 bit version of Windows.
Note I have already tried to install using compatibility mode.
Thanks in advance.
Terry
2 REPLIES 2
Hi again,
I'm currently scaping a large L off of my forehead. It works better if I download and install the correct 64 bit version rather then the 32 bit version. Problem fixed.
dmillar
in reply to: terry_kesteloot
I am using Windows 7, and I cannot get the 64bit version of Trueview to install.
I do not think it is compatible with Windows 7. If anyone has a suggestion, you could email me @ "dj.millar@bell.net".
I even downloaded the dll replacements.
