Show only
Search instead for
I'm getting an error message on install that Treuview is not compatible with Windows 7. Is this a bogus error message? If so is there a way around it? If not is there a release date for the 64 bit version of Windows.
Note I have already tried to install using compatibility mode.
I'm currently scaping a large L off of my forehead. It works better if I download and install the correct 64 bit version rather then the 32 bit version. Problem fixed.
