• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    Active Contributor
    zingero84
    Accepted Solution
    Where do I find NET 4.0 SP1 for TrueView 2013?
    62387 Views, 15 Replies
    03-28-2012 07:36 AM
    I've looked everywhere and tried a few downloads.  I cannot find this file.  It's very frustrating.
    Any help?
    Please use plain text.
    New Member
    Re: Where do I find NET 4.0 SP1 for TrueView 2013?
    03-30-2012 12:19 PM in reply to: zingero84
    I am experiencing the same problem.  I did find a Framework product, but it must be the wrong one because i get the same error message after loading it up...
    New Member
    04-02-2012 10:55 AM in reply to: zingero84
    Active Contributor
    zingero84
    04-02-2012 11:02 AM in reply to: zingero84
    I tried that one last week and it didn't work.
    New Member
    04-27-2012 12:07 AM in reply to: zingero84
    Installing NET 4.5 beta works
    Active Contributor
    zingero84
    04-30-2012 10:47 AM in reply to: Blackbird89
    link?
    New Member
    05-03-2012 06:35 AM in reply to: zingero84
    I was receiving the same error, need Net 4.0 SP1, on a 32 bit Windows XP machine.  I believe there is an problem, but the error message  is referencing the wrong version of Net.  Once I installed SP3, NET4, and allowed windows update to patch all of the versions of NET versions 1.0 - 4.0, and add the security updates, Trueview 13 installed with no issues.
    New Member
    05-07-2012 05:27 AM in reply to: zingero84
    I haven't been able to get past that either. I've installed and reinstalled .NET 4, (dotNetFx40_x86) installed all .NET updates from Windows update and installed KB2478063. Do you have to have Visual Studio installed to run it? Part of update 1 is VS10SP1-KB2495593 which can't be installed without Visual Studio.
    Product Support
    05-24-2012 05:33 AM in reply to: zingero84
    Try this link:
    http://www.microsoft.com/en-us/download/details.aspx?id=3556
    Any luck?
    Best regards,
    Silvia
    Silvia Menon
    Support Specialist
    Product Support
    Autodesk, Inc.
    http://www.autodesk.com/autocad-support
    Active Member
    05-27-2012 09:10 AM in reply to: zingero84
    You want the Full version of the Dot Net installer: dotNetFx40_Full_setup.exe
    It can be found at: http://www.microsoft.com/en-us/download/details.aspx?id=17851
