• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    New Member
    rjaneiro
    Unit of measure
    1825 Views, 4 Replies
    12-28-2010 11:17 AM
    The drawing that I am viewing using DWG TrueView provides dimension in feet and inches when measure objects.  Is there a way to have the measures provided in metric / millimeters?
    Please use plain text.
    New Member
    toadoftoadhall
    Re: Unit of measure
    11-25-2011 04:10 AM in reply to: rjaneiro
    over 300 hundred views and no replies. I guess there is lots of interest, but no solution.
    toad
    pendean
    Re: Unit of measure
    11-28-2011 05:10 AM in reply to: toadoftoadhall
    The file creator controls all aspects of the file: not much you can do in the viewer except view it as created.
    To change units, the file must be scaled first, unless you want to endlessly do the math: AutoCAD works with "units", a generic measurement that can be inches, mm, meters, or even lightyear and are not interchangeable with a button or switch. The file creator, or anyone able to change the file (not the viewer) must scale to redefine "units".
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    New Member
    TrueView Unit of measurement
    05-14-2013 05:54 AM in reply to: rjaneiro
    Is there any possibility to see in viewer which are the units the measurements are done (cm, inch, m, etc)? Thanks
    pendean
    Re: TrueView Unit of measurement
    05-14-2013 06:05 AM in reply to: sorpic
    Measure a known distance and compare it with what the program reports.
