DWG TrueView
Active Member
jsdraft
Message 1 of 15 (4,690 Views)
Unable to install DWG Trueview in Windows 8
4690 Views, 14 Replies
03-11-2013 12:28 PM
I have done a search and unable to find the answer specific go my problem.
I have downloaded DWG trueview 64bit to my download folder. Right click and hit open.....nothing happens......Try to delete the exe file and get an error File in Use "The action can't be completed because the file is open in SetupDWGTrueView2013_64bit.exe"
Whats up.?
Running Windows 8
Architecture 2009
CPU HP Pavilion AMD proc
Thank you for comments and suggestions.
JSdraft
Active Member
jsdraft
Message 2 of 15 (4,682 Views)
Re: Unable to install DWG Trueview in Windows 8
03-11-2013 12:54 PM in reply to: jsdraft
Restarted machine.
Downloaded the 32 bit file this time and it seems to have worked except now it hangs up on initializing with a "The system cannot open the device or file specified"
now what?
*Expert Elite*
pendean
Message 3 of 15 (4,671 Views)
03-11-2013 02:11 PM in reply to: jsdraft
Windows 8 is not currently supported.
You might have luck trying something like this:
http://www.cadforum.cz/cadforum_en/how-to-install-autocad-2013-and-inventor-2013-in-windows-8-tip903...
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
brett
Message 4 of 15 (3,891 Views)
07-08-2013 12:57 PM in reply to: pendean
Does this apply to DWG Trueview 2014?
I am trying to install on a Windows 8 Pro 32bit Dell Latitude Tablet.
When trying to open a drawing is says it's missing a diplay driver (.hdi) in the \drv\ directory.
Brett
*Expert Elite*
pendean
Message 5 of 15 (3,889 Views)
07-08-2013 01:04 PM in reply to: brett
It should for 2014 version, but it's not officially listed (or I can't see it):
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
Can you post a scrneeshot of the exact error?
New Member
portt
Message 6 of 15 (3,867 Views)
07-10-2013 06:39 AM in reply to: jsdraft
New Member
portt
Message 7 of 15 (3,866 Views)
07-10-2013 06:40 AM in reply to: portt
that's dwg trueview 2014 also
New Member
brett
Message 8 of 15 (3,864 Views)
07-10-2013 06:45 AM in reply to: portt
portt, thanks for posting the screen shot.  I hadn't gotten around to it yet.  That's exactly the same message I'm getting.
Member
fakerr
Message 9 of 15 (3,370 Views)
08-29-2013 02:48 AM in reply to: jsdraft
same Problem here with the Dell Latitude Win 8 Pro.
A display driver file .hdi is missing or has been corrupted when i want to open a file.
Someone can help?
Member
fakerr
Message 10 of 15 (3,349 Views)
08-29-2013 05:19 AM in reply to: jsdraft
After a while i resolved the Problem with Win 8 Dell Latitude and TrueView 2014.
1. Open "Regedit"
2. search for "CustomHeidiDriverPath"
they are two of them in the Registry. Delete both on the right side.
And it works fine :-)
You are not logged in.
Announcements
Need installation help?
Ask the Community
