• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWG TrueView
    Trueview export to DWF/PDF message
    1065 Views, 5 Replies
    09-21-2011 01:39 PM
    Anytime I export to DWF of PDF I get a message "DWF application not found".  Stating it can't find DWF viewer and provided Design Review download.
    What make this interesting is I have Design review installed and Acrobat Pro.  With both DWF and PDF they preview just fine in their respective programs.  I get this message for PDF export too, even though it's not a DWF.  To add to the strangeness, if I turn off Preview for either export the message still appears, but the exported files do not preview as requested.
    The only way I've been able to turn it off is through the "Preferences" dialog.  The only preference option is to turn off preview for DWF.  However, if I restart Trueview the message(s) return and I've not been able to identify a registry setting to control this.  It's not really and issue, just annoying.
    Thoughts?
    Chris
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Trueview export to DWF/PDF message
    09-21-2011 01:53 PM in reply to: chriscaron2617
    What version of TV do you have?
    What version of ADR do you have?
    Did they both come from the same single download of ADR?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    09-21-2011 01:54 PM in reply to: pendean
    2012 for both.  Un-patched.
    ADR is from ACA 2012, Trueview is standalone.
    11-06-2012 09:52 AM in reply to: chriscaron2617
    Update:
    Still an issue, now with ACA 2013, TV 2013, ADR 2013...!
    *Expert Elite*
    pendean
    11-06-2012 12:07 PM in reply to: chriscaron2617
    You can use ACA2013 to turn off the preview option in the PC3 files that it and DTV uses.
    11-19-2012 08:36 AM in reply to: pendean
    Turning off preview still gives the message, no change.
